Refrigerators Logo
Posted on Feb 27, 2009
I have water leaking heavily from the inside top of refrigerator,
Model style is freezer on top of refrigerator
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
195
Points
Water is leaking inside the refrigerator from a bottom vent from the freezer. What is causing this?
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
My refrigator is leaking water
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
hope this helpout ......
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
1helpful
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
5helpful
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
1helpful
Refrigerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
