Posted on Feb 27, 2009
Melted exit rollers SF 2020 Sharp copier
From Ralph McCoy, teacher at Ayers Elem. School, San Francisco.Our Sharp SF 2020 has exit rollers that look as if they melted. Can I purchase the parts? How do I open the copier to install the roller? Thanks!
  • trecartin Mar 18, 2009
    Need to replace exit roller. Where can I find one?
A
Anonymous
Please.....do yourself a favor, and call a service tech.
6helpful
3answers
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
1helpful
2answers
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
1helpful
2answers
2helpful
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Sharp copier sf2530
Paper exit drive overloaded in sorter. Make sure that the finisher trays are not too full of paper.
3answers
Sharp sf-2020 4?'s please
pleaz check it in internet by loging www.sharp copiers.com
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
