SOURCE: Pioneer Receiver will not come on
press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
SOURCE: I have a pioneer VSX-1019AH-k receiver connected
Hi, I have the same Pioneer receiver, and the same TV, with a Harmony (p.o.s.) remote - and the closed captioning is not available when I select it on my remote. My problem is ever since Sunday night I have closed captioning on all the time. It's not from my remote and I have no idea how to turn it off. Any ideas?
SOURCE: I have a new LG 42LD520 LCD TV which I'm trying to
Normally the LG TV Optical output will require an optical cable and not a PCM. So I am not sure if you are connecting the correct cable. The Pioneer can take both input types but the LG TV will only provide Digital output in Optical connection. PCM is a co-axial connection.
Assuming you have the correct cable you will need to assign the correct input types in the Pioneer receiver by selection using the setup menu. Do you have the user manual for the Pioneer receiver?
