SOURCE: Whirlpool DUC600XTPQ6 Quiet Partner I
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
SOURCE: Whirlpool Quiet Partner 980
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
SOURCE: whirlpool quiet partner II top rack sprayer doesnt
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to
access the wash motor. Remove the 4 torx screws and the filter
(accumulator assembly). Remove the torx screw and the inlet protector
that covers the chopper assembly. Make sure the chopper is not broken
(broken chopper will fill with debris and block water flow). While
holding the chopper blade, reach inside the "D" shaped opening on top
of the motor and spin the wheel/motor by hand in each direction to make
sure either the chopper gear or the motor gear that drives the chopper
is not broken. Replace the chopper if necessary (part # 8268383). If
the motor gear is broken, replace the sump and motor assembly (part #
8535150). Remove any debris from the sump area in the process.
You
don't have to shut the power off to the dishwasher because the door will be open, but if you feel more
comfortable, do so.
