I had a similar problem with my D-90 when I attempted to down load several video clips from the SD card in a card reader. Don't know why this happens but I was able to get the long clip by manually copying it from the SD card to a folder on my computer.
I then manually deleted the video file from my SD card. Until I read your problem, I could not figure out why that particular file would not download like the rest of them did. The other clips were 19 minutes but the long one was 22 minutes. It appears the limit for auto downloads may be 20 minutes. I have another camera that breaks long videos into 19-minute clips and I suspect the reason 19 minutes is the length is because of this aspect of Windows.
SOURCE: I had 4 videos I recorded with my L20. I was able
Try using a card reader to download them to a folder you create on your desktop.
SOURCE: HD videos won't upload to computer?
How are you trying the upload? Is your camera connected via USB or are you using a card reader? What program(s) are you using?
You should be able to do the upload by using a card reader and the operating system's file explorer to copy the file.
Please
follow the steps to transfer video to a computer using an i.LINK connection
(IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must
be installed on the computer. Depending on the computer manufacturer, various
video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft
Windows Movie Maker, etc.) may be available or already installed on your
computer. If necessary, contact the manufacturer of your computer for further
information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate
Plus software for video capturing. Some VAIO computers also include Click To
DVD software that will allow video capture to the computer hard drive or
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
NOTE: The computer i.LINK ports and capture cards
may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK
ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will
be necessary to use a 4-pin to 6-pin i.LINK cable.
