Question about NiceCycle Suzuki Gsxr 600 750 06 Color Changing Hyper LED Halos
Common 06gsxr electrical problems
Have to push start bike but runs fine when started. Bike wont jump off
    New Friend:
    Problem Solver:
  • 7 Answers
Seems like calibration was lost
Posted on Mar 19, 2013
6ya staff
SOURCE:
I jump started my 96 thundercat with a halford's jump start box and when i take the leads off it starts to run badly why would it do that?
sounds like the jump starter is supplying regulated power to the spark generator/distributor, without this smoothed power the alternator is feeding unregulated to it.... placing a good battery across the terminals after jump starting should prevent this mis-firing fault.
Nov 23, 2017 | Arctic Cat 2006 F6 Firecat EFI Sno Pro
Electric fine bike wont start
Many motorcycles that are newer have a built in safety device that keeps the bike from starting when the battery is too low to keep from burning out components from running low on voltage. Can you hook a battery charger to it and have it start or is it just turning over and not starting? Without any details about your problem it is hard to troubleshoot. Has the bike been ridden recently, has it been setting so the carb is gummed up, is it fuel injected, does it have an electric fuel pump?
Oct 18, 2014 | Motorcycles
Bike wont start, something with the Battery circuit or battery, we can push start the bike so the bike does run, I charged the battery and had the battery tested and it tests out fine, when I put in bike...
From your description, it sounds like a bad starter motor. That is provided all of the cables going from battery to relay, and relay to starter are not corroded or have poor connections. The relay is a weak point, so it may be damaged as well if the starter has been pulling too many amps.
Oct 13, 2013 | 2000 kawasaki ZRX 1100
Bike cranks over. Battery fully charged. Wants to start but won't. I can jump start it and it runs fine. I can push start it from second and it runs fine. I shut bike off and it won't start back up. Fuses...
the starter motor is probly du for a makeover-1st chec if contact cables r tite or corroded--its not hard to repair usually its somethin simple like brushes-getta a clymer book ther detailed for the whole bike--
Aug 21, 2010 | 2001 Suzuki GSX-R 750
Bike wont start , the solenoid just clicks
If you push the start button and the solenoid clicks the button is good. Find the solenoid ( usually by the battery follow the positive cable.) and jump the two posts with a screw driver, piece of wire , or jumper cables if the starter now works you need a new solenoid. At this point you either have a bad battery or a bad starter. Jump the bike with a good automotive battery (can be in the car just make sure car is not running or you could damage bike.) If bike starter still does not work try new starter brushes for a Goldwing they are cheao and easy to replace. If brushes look good ( not down to wear marks ) you need a starter ( bad armature ). I'm guessing the solenoid is bad (first choice) or you need brushes. Good Luck
May 04, 2010 | 1983 Honda GL 1100 Aspencade Gold Wing
Honda XR125 L-4 3 month old battery, Bike has engine has started to die, exhaust goes pop (backfire?), engine cuts out all together, battery almost completely dead wont restart bike, starter just clicks...
put a volt meter across the battery terminals, should read over 12v stopped and rise to 13.5v with the engine running.
If the voltage doesnt rise there is a problem with the charging circuit.
Be carefull starting from a car, as this can cause damage to the bikes electrics, as the bike tries to produce enough amps to charge up the car when the bike starts, and overcook electrics.
Apr 19, 2010 | 2002 Harley Davidson FXD Dyna Super Glide
Battery...cant find out how to get to it ...can I jump it
If your battery is completely flat you will not be able to push start it as you will get no spark.
I think you need a manual and you can download it here free:
http://www.carlsalter.com/aaman/Honda_CBR1000RR_Servicemanual.with.hyperlinks.pdf
Please leave fair comment if I have helped you.
thanks for that
Sep 16, 2009 | 2008 Honda CBR 1000 RR Fireblade
Bike runs fine then stalls when ya try starting again it wont as battery is flat is this common on xs 1100 1980 bike will start no trouble via a jump start
If you have a voltage tester you will probably find a low reading on your battery. It takes a big powerful battery in excellent condition to start that monster, that's why it starts right away when you jump it...Good Luck to you !...Tim
May 03, 2009 | 2002 VOR SME 500
Burgman 250 will not start
Ck fuses and wire connections first. If no problem seen, get bike running and disconnect the ground cable @ battery. If bike dies the problem generally is in the stator or regulator assembly not keeping battery charged. Bike will run untill the battery is too low to keep the ignition system energized and the bike will die. If it continues running w/the ground disconnected, the battery could have a dead cell which will drain the battery in a very short time whether it is running or not.
May 03, 2009 | Suzuki Burgman 250 Motorcycles
Bike wont start
Remove battery and get it charged the tested..More likely its failed. when engine is running check battery voltage it should be 12.8 to 14.2 volts with good battery
Jan 31, 2009 | 1991 kawasaki ZXR 250
NiceCycle Suzuki Gsxr 600 750 06 Color Changing Hyper LED Halos Logo
95 people viewed this question
Top NiceCycle Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a NiceCycle Cell Phone Expert? Answer questions, earn points and help others
