Dear friend, I provided some useful links about this problem (Error 2048), read them, I hope they could help you:
[Solution # 1]
http://www.moviecodec.com/topics/41979p1.html
[Solution # 2]
http://critiquewall.com/2006/02/15/avi-problems-quicktime-error-2048
[Solution # 3]
http://www.smartcomputing.com/techsupport/detail.aspx?guid=&ErrorID=32119
[Solution # 4]
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb403032
At the end, I suggest you also to install DivX on your computer or check your file by other players like VLC Player.I guess it could help you.
Good luck
QuickTime error 2048 somtimes make you can't play file such as MP4. There can be multiple reasons that QuickTime Player can't open MP4. It could be just a glitch or a complicated cause. But it's worth noting that MP4 is a file format or container. You can imagine that it is like a box that has your video, audio, and metadata in. Here MP4 defines how the video, audio, and metadata are stored within the container.
Sometimes you can even swap out the container without changing the file type. The container format is completely different from the video format(video codec). MP4 can use various video and audio codecs, sometimes H.264 for video and AAC for audio, sometimes others. That's why sometimes your QuickTime Player can support MP4 playback, occasionally it doesn't.
Source: can't open MP4 with QuickTime Player
This error is most commonly happen to software related to QuickTime player. QuickTime Player sometimes fails to play certain files and users receive QuickTime error 2048.
There are 3 ways to let you play MOV files on PC: install codec package for your Windows Media Player to let it be compatible with MOV files, adopt 3rd-party MOV compatible media player software, and convert MOV file to MP4 or other formats
Error Code 2048 most commonly indicates that the device cannot acquire network resources. Error 2048 most commonly indicates one of the following situations:
To troubleshoot error 2048 With the phone on, remove the battery from the phone for one to two minutes. Reinsert the battery, and then attempt to log in again
NO PC told at all, FAIL you will. 100000 PC and many OS and versions
and quicktime soulld never be used on windows, if is.
https://us-cert.cisa.gov/ncas/alerts/TA1...
