The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: E18 error message
Twist the extended lenses if extended or if not extended remove cover ring and twist the base. Put in fresh batteries and turn on. If no joy try again or google this problem. Solution on cnet.com
First try pressing the DISPLAY button. If that doesn't fix it then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: my canon A470 digital camera NOT WORKING ! LENS
The lens barrel is damage and needs replacement.
Southern Photo Technical Service is a Authorized Service Center for Canon.
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $110.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
SOURCE: canon powershot A470 problem when i click photo
Go to the menus and find the set to default option.
This should reset the menus and options to original.
Go to the menu section find a setting something like this... such as.. reset all to default or set to factory default or simply RESET.
Check to see if the pictures are saved to the card by taking a picture, then remove the card and play it back in either another camera or use a card reader to read the card.
If these tests shows that no picture was taken or it is all white, then the camera needs repair or has a ccd problem.
Another option is to call Canon Repair at the following page and use the 800 number for calling the repair department.
Canon has a trade-up or trade-in program which is a great way to get another camera at a good price. Canon will allow you to trade in your camera for a reasonable price against a refurbished camera plus a cost which is reasonable. A refurbished camera will come with everything it had when new, and will have been restored to original specifications.
SOURCE: White photos canon A470? i have a canon
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
