I had to do a repair job with a bad solder on the circuit board, but now the light no longer works. The bad solder I fixed resolved the issue with the lengthy cycle time, though.
Please can you look at this link
http://www.bosch-home.com/us/support/safety-notices/dishwasher-recall.html
Some of the bosch dishwasher are subject to a recall the problem is exactly the fault you have tried to rectify in your submission. The recall is free of charge and the units are between 5 and 14 years old. You will need to enter the full ENr, FD and Serial No to check if yours is affected.
SOURCE: Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
SOURCE: BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
SOURCE: Bad smell
Most problems with smells in Bosh Dishwashers come from failure to have the 20" rise in the drain line between the dishwasher and the drain as the installation manual requires.
My factory installer failed to do this. After looking at the installation manual, which shows a 20" rise, I used electrical ties to hold the drain line 20 inches above the floor. The smell which was causing us to run the rinse cycle every day to get rid of the smell has not been back in five days.
SOURCE: Our Bosch Dishwasher no longer
Unfortunately that indicates a control module problem. Only fix is to replace that
HERE you can find the parts and drawing
SOURCE: had a clogged garbage disposal, once fixed, the
if you didn't do the disposal fix yourself then there's a possibility that whoever did it closed the water valve to the dishwasher although there is no good reason to do that...
I would check the valve then make sure that a severe kink wasn't put in the water supply line while working on the disposal...
one other cause could be a relay switch stuck in the closed position which will not allow water to the unit and would of course be a total coincidence and unrelated to your disposal repair.
