The alarm clock has an ipod/iphone flip down docking staion
Its actually really irritating. You have to turn off all the alarms i.e. so no little bell icons are showing in the display and also turn off the radio i.e it shows OFF. Then, and only then, if you hold down the SET button you will be taken to the time setting menu which starts with a blinking 12H sign. Once in this menu its like any clock radio - you push up or down on the right hand side to select higher or lower numbers and hit SET again to progress to the next feild. You must complete the entire setup menu i.e you must keep hitting SET until you are back at the main screen or it will just forget what you entered go back to whatever it was before you started. Very opaque if you dont have the manual, so I thought everyone else could get 45 minutes of their life back. BTW, the holding down SET with the iPOD in the dock doesnt work for me - its supposed to according to some entries on the web.
SOURCE: I can't turn off either
Regards,
Tony
SOURCE: Timex T158W Alarm Clock
Hold down the "buzzer", "radio" or "sound" buttons until you hear a beep and one of those words is blinking. then, use the arrow keys to go up and down by minute and only by minute (which means you are going to have to wait awhile if you want to change the time to many hours ahead or behind). When you get to the time you want, press enter.
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
SOURCE: lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
SOURCE: lost manual for Timex Nature Sounds MP3 T158W
Here is a link to the manual you seek
http://www.timexaudio.com/pdf/T309_IB57517_39.pdf
