Whirlpool ED2FHEXN Side by Side Refrigerator Logo
Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator not cooling although lights and sound are OK
My Whirlpool Conquest 25.55 cu. ft. Model # GS6SHAXLQ01 is about 7 years old. I left it on when I was out for 4 weeks. In my absence there was a 15 hour power failure. On return I found that although the lights and the sound of the motor running are OK, but it is NOT cooling and also NOT making ice. I emptied and cleaned it throroughly. I also vaccumed the condensor coils behind the front grill at the bottom. It was very dirty. Then I started the refrigerator again but it is still NOT cooling even after 6 hours of running even though the lights are ON and the sound of the refrigerator running seems normal. Ice is NOT forming but water does flow out of the dispenser. CAN SOMEONE PLEASE HELP. I have a Whirlpool Side By Side (Model #ED2PHEXM) refrigerator that is not cooling or freezing. Lights work and fan is running. Sounds as it always did but freezer not freezing or fridge not cooling. Cleaned it and dusted thoroughly...no luck!!
  • amber_herrin Apr 11, 2009
    I have the same problem...
satya prakash sahoo
Level 2:
Sergeant:
Champion:
  • Expert 214 Answers
  • Posted on May 14, 2009
satya prakash sahoo
Expert
Level 2:
Sergeant:
Champion:
Answers
214
Questions
0
Helped
65691
Points
546
Your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
3 Related Answers
Ken Bledsoe
  • 306 Answers
  • Posted on Jan 12, 2009
SOURCE: Report abuse posted by OG
You have a relay on the compressor called a PTC relay. That little guy is bad. Make note of the wires and where they go. Take the relay and make and model number to a appliance repair house and get a new one. To remove the relay you have to remove the wire retainer clip and take off black cover then pry off the little relay they are on snuggly just pull straight off. let me know if I can help any more. ken
Anonymous
  • 43501 Answers
  • Posted on Sep 29, 2010
SOURCE: Refrigerator not cooling although lights and sound are OK
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
\ fbvb
Anonymous
  • 43501 Answers
SOURCE: Not cooling or making ice - fan and lights OK
heatman101
iufgh
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
1helpful
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Whirlpool refrigerator model GD5rha does not cool but freezer portion does.
replace the control board usually lights are out in refrige side also ans temp readout is also out part # 4334000 appliance parts pros $80.25 shipped
The lights are on but it is not cooling or freezing
The overload/relay is shorted . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Pt # 8201786 . Remove the back refrig panel to access the compressor . This part is easily replaceable . Instruction come with the part(s) . A little plastic "clip" needs to be released , when removing the plug from the part , by using a small screwdriver .
Whirlpool Gold GS6SHEXNL - Freezer works, Refrigerator cools but display and lights do not work.
From about an hour of searching your refrigerator I found that the problem is in the control board mounted on the back of refrigerator. Visit this link below and enter model number GS6SHEXNL into the search model and parts search feature. When you get to your refrigerator on left of screen is different prints, chose #11 and you will #18 in picture. Click on link below and following links to support this problem. Model GS6SHEXNL Part Number W10135090
http://servicepartstec.blogspot.com/
refrig-problem-5577/">http://www.diychatroom.com/f47/whirlpool-refrig-problem-5577/
If you need more help, just let me know, Thanks, Sea Breeze
heatman101
iufgh
1helpful
Report abuse posted by OG on Jan 12, 2009 My Whirlpool Conquest 25.55 cu. ft. Model # GS6SHAXLQ01 is about 7 years old. I left it on when I was out for 4 weeks. In my absence there was a 15 hour power...
heatman101
\ fbvb
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
