SOURCE: Fork oil level: 2006 KDX 200
This all depends on what size forks you have, but a good rule of thumb is 120ml. After that then what you want to do is to ride the bike and make adjustments to your front end until your liking.
SOURCE: i have replaced fork seals
I am assuming the old oil is drained.
Once the tops are opened, lift the bike onto the center stand which will make the forks extend. Refill through the top of the fork with 12 oz of fork oil. The manual states that you must use oil with a weight of approximately SAE 3, and the amount going in needs to be equal in each fork.
Hope this helps
SOURCE: How much fork oil in a 2002 KTM 400 SX
White power allow a 110mm air gap with springs out and fork compressed as a general guide ,adjust from there according to prefrance . Thats probably,from memory about 600ml or so.If you overfill the leg ,cut the tip off the fork oil bottle , mark out on a clear piece of fuel hose 110 mm from one end of hose with a permanent marker, attach other end to the tip of the now empty fork oil bottle nipple, squeeze bottle,insert hose down to 110mm mark,take hand pressure off bottle and WWHHAAALLLAAA!!!!!!!!. Magically the excess oil is sucked back up into bottle.....Don't you just love the forces of nature. : ] ride on DB ......Hope this gets you out of trouble ....Flabbycat
SOURCE: front fork leaking oil from bottom of the seal.
Before you take it to the shop try this.Get some camera film,Cut the notched edge of it and trim the top to an angle of 45 deg..Slide this up into the fork seal and working it up and down,slide it all the way around the seal.When you get the feel of it,you can feel tiny bits of grit.This will clean the grit out 99% of the time.I always keep a piece of film in the toolbox.
SOURCE: how to take apart a mongoose tyax elite mountain
the quickest way I find:
is to take to it with a sledge hammer, sure some of the parts end up getting a tad damaged but it works all tje same, have funnnnn
