Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My kenmore fridge model # 253.55693402 the bottom right is cooling and nothing else is working
The water is not coming and the ice is not making and only the bottom right is freezing
Anonymous
SOURCE:
Anonymous
  • 42 Answers
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Posted on Jan 25, 2008
Anonymous
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
Anonymous
  • 11 Answers
SOURCE: Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
Anonymous
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Posted on Aug 13, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
Km 280 mwf stop making ice just make cold water hit the reset button and nothing .the ice it is making come out so small it melt befor it hit the bottom .
look for stuck water valve, reservoir leaking water causing short freeze cycles. start there and let me know if I can be of any further help.
Nov 12, 2010 | Hoshizaki Cubelet Ice MakerDispenser Water...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
Aug 11, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Water for some reason is coming out of the bottom we just happen to find it. also It is drippinging and freezing in the bottom of the freezer we clean it out and it comes back, but the water on the floor...
Sounds like you have a side-by-side...
The defrost drain is probably clogged or frozen. When the fridge runs a defrost cycle the melted water cannot reach the evaporator pan underneath the refrigerator. Some water makes its way out onto the floor to wet your socks, and some re-freezes inside the bottom of the freezer compartment creating a layer of ice.
Jul 25, 2008 | Frigidaire Refrigerators
Ice Maker Not Making Ice BUT making a "trying" sound
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
