Toshiba Satellite A205-S5879 Laptop Logo
DJ Scorpio Posted on Mar 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought another toshiba satellite laptop. But will only work in safe mode and networking. It happen right after I upgraded the webcam, blue tooth. realtek sounds, wifi and video drivers. I don't
OS Name Microsoft Windows 7 Ultimate Version 6.1.7601 Service Pack 1 Build 7601 Other OS Description Not Available OS Manufacturer Microsoft Corporation System Name DJSCORPIO-PC System Manufacturer TOSHIBA System Model Satellite A205 System Type X86-based PC Processor Intel(R) Pentium(R) Dual CPU T2390 @ 1.86GHz, 1867 Mhz, 2 Core(s), 2 Logical Processor(s) BIOS Version/Date TOSHIBA V2.50, 6/11/2008 SMBIOS Version 2.4 Windows Directory C:\Windows System Directory C:\Windows\system32 Boot Device \Device\HarddiskVolume2 Locale United States Hardware Abstraction Layer Version = "6.1.7601.17514" User Name DJScorpio-PC\DJScorpio Time Zone Central America Standard Time Installed Physical Memory (RAM) 3.00 GB Total Physical Memory 2.99 GB Available Physical Memory 1.66 GB Total Virtual Memory 5.98 GB Available Virtual Memory 4.27 GB Page File Space 2.99 GB Page File C:\pagefile.sys
max carson
Level 3:
  • Toshiba Master 7,627 Answers
  • Posted on Mar 18, 2013
max carson
Toshiba Master
Level 3:
Answers
7627
Questions
Helped
1013678
Points
21773
Did you try a System Restore/recovery? Unplug, remove battery, plug in, reboot . Use this procedure to restore to a date before the updates, Did you get the Updates from Toshiba website? https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2737864&pf=true The specs show that machine had Windows Vista originally. Do you have a Windows 7 Repair disk? For a disk try here: http://www.lifehacker.com.au/2011/08/download-windows-7-isos-to-reinstall-without-restoring-your-system/ OR here: http://www.mydigitallife.info/windows-7-iso-x86-and-x64-official-direct-download-links-ultimate-professional-and-home-premium/
3 Related Answers
nickpower
nickpower
  • 43 Answers
  • Posted on Dec 22, 2008
SOURCE: Toshiba laptop Dual display issue
To switch between screens try pressing the FN key and F5. You should not have to restart you computer. As for the TV error "invalad signal" you might have to change the screen resolution on you computer. You might have to try a few different resolution before you find one your tv accepts.
1. Open Display Settings by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Anonymous
  • 561 Answers
  • Posted on Mar 16, 2010
SOURCE: same problem, i downgraded it to XP. Now i cant
Hi
Thank you for your query
Please try the following
1) Go to www.devicedoctor.com and download and install the software
2) Load up the program and then click on 'begin scan'
3) This will scan and hopefully pick up the missing drivers for your sound
4) Click on download for the sound drivers
5) Install the drivers and enjoy
I hope this has been useful
Anonymous
  • 59 Answers
  • Posted on Jan 15, 2011
SOURCE: Dear Sir/Madam, I did attempt to
you need a new dvd drive. they aren't expensive and they're easy to replace
When I load my Toshiba Satellite L305D-S3958 It loads up saying it didn't shut down successfully. I tried all the modes from safe mode, safe mode with networking, safe mode with command prompt, and Star...
I hope that you have a goood back-up of file. Getting blue screen error is a fatal OS problem. You need to re-install windows.You need to get the CD that came with your computer or the operating system disc you used to install the windows. Insert the disc on the CD-DVD drive and restart your computer. Watch for a Press any key to boot from CD or DVD... message. Installation will start. Good Luck!
Hang problem Toshiba satellite a205-s4607 Laptop what will i do? any solutions? Intalled new 500gb hd and upgraded memory to 4gb total. then reformat it to its orig OS Vista It flickers.
May be your Computer is infected and check for cables.
You need to run your computer through Safe mode with Networking and run the Anti Malware bytes and ccleaner(Run this software and analyze first and then Run Cleaner)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
2answers
My laptop shuts down right after booting up. It shows a blue screen witha message about checking the configuration of drive c. It gets to about 75% complete and shuts off! HELP!!
Try to boot up in safe mode, done by pressing F8 while computer is booting up then restart and let computer boot up regular, if you installed any drivers before this happen unistall them while you are in safe mode.
1helpful
Safe mode button for toshiba satellite windows xp a45
Press and hold F8 while booting up to access Safe Mode functions which include Safe Mode with Command Prompt and Safe Mode with Networking. Hope this answers your question. Best of luck!
Greg
2answers
Windows wont boot up when I turn on my Toshiba
You need an antivirus program to be installed after installing your operating system. Do it in safe mode. If problem persists let me know.
2answers
Bluetooth conection
you have to activate blue tooth connectivity on your phone
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
