Keep doing regular oil changes , fuel and air filters if they havn't been done for a while. Timing belt every 100,000 km.
Everything else only as needed . Brakes , shocks , exhaust , etc.
You have a problem with the pass seat belt or the wiring to it.P/T stands for pretensioner. when the air bag deploys the seat belts tighten.
Be carful with the seat belt it contains an explosive.
call your triple A Co. or tow truck provider. Special tools are used and are not available to the general public. If its an emergency break the side window and deal with replacing the glass later.
You shouldn't need to most of the time all you need is a 15mm wrench. Use it by turning the spring tightener inward toward the center of the motor than the belt should come off. Also when you take it off make sure you know how the belt goes around the pulleys so everything will work together like normal. when putting the belt on you should use the wrench to turn the tightener back inward and slip the belt back on and make sure it looks just like the old one when its on.
