Cameras Logo
Anonymous Posted on Mar 17, 2013
Will the Quantaray 49mm to 55mm step up ring work on a Sony a100 DSLR camera
We had to buy a new camera which is 55mm (Sony a100 DSLR). Our old camera was a Minolta 49mm. We have several new filters that we bought for the Minolta that we'd like to use on our Sony.
crawdad505
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jan 19, 2015
crawdad505
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
2359
Points
32
If I'm reading this right, you had a Minolta dslr and had a 49mm lens on it and purchased a Sony dslr with a 55mm lens. You could use a step down adapter to put the 49mm filters on the 55mm lens but it would greatly reduce the picture quality. It would have an affect on the picture like closing one eye and look at your computer, then form an 'O' with your thumb and forefinger and put it up to your eye and look at your computer. That is the effect you would have with the smaller filter on the 55mm lens. I would suggest putting the 49mm lens from your Minolta on your Sony and just using your filters on that lens and purchasing a 55mm UV filter, or the set with UV, CPL (circular polarizing), and FD filter. These can be purchased on ebay fairly inexpensive. If your Minolta camera was digital and had auto focus and had a detachable lens it will fit on the Sony.
(press the button on the front of the camera where the red dot is on the side of the lens, and while you are holding the button down grasp the lens and turn it counterclockwise). Be extremely careful an not let any debris fall into the camera when the lens is off the camera! It is a good idea to tilt the camera slightly forward when the lens is off. Do not touch the mirror inside the camera when you have the lens off. You also have to be careful when changing lenses outside when it is windy. I hope this answers your question
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Cameras Master 102,366 Answers
  • Posted on Mar 18, 2013
Cameras Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428985
Points
622693
The step-up ring will on any lens with a 49mm filter thread, regardless of the manufacturer. The easiest way to find out whether it works with any given lens is to see whether the ring fits onto the front of the lens (you could also read the filter size written on the lens itself).
If it doesn't fit, purchase the appropriate step-up ring. That will be much cheaper than buying a whole new set of filters.
If the new lens(es) have a 55mm filter thread then you don't need the step-up ring at all. The filters will mount directly onto the lens.
  • Anonymous Mar 18, 2013
    If I understand, I actually need a step down ring. My new camera is 55mm, and the filters I want to use are 49mm. Correct?
  • kakima Mar 18, 2013
    Sorry, my fault. You are correct, you need a step-down ring. Be careful though, using a smaller filter may cause the corners to be cut off. Try looking through the camera while holding a filter to the front of the lens. If the corners darken then you'll have to bite the bullet and buy new, larger filters.
Sony dslr a100 won't switch on. battery ok
the problem is with the CF card nit the camera
get a new card and your good to go
1helpful
Sony Alpha DSLR-A100 lens got wet and now it does not focus. Will buying new lens solve the problem?
If the lens was the only area to get wet then yes replacing it should resolve the issue.
Take apart sony alpha a100
Before attempting to take the camera apart, make sure to refer to the user manual. It will contain diagrams and schematics for the device:
Sony Alpha DSLR A100 manual
I found a Quantaray 55-52 mm step down ring (Manufacture # 241664614) on Wolf Camera's website that I am interested in purchasing, but want to make sure it would work for me. I have some close up...
No. The 55-52mm step-down ring will let you attach a 52mm attachment onto a lens with a 55mm thread. You want a 52-55mm step-up ring.
Mar 21, 2011 • Cameras
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
4helpful
I lost amual for my SONY a10... can't remember exactly how
Click Sony Support and download required instruction manual of Sony DSLR-A100
I would like to know what these do
Bower is brand name skylight is slightly yellow helps soften light there are diffrent densitys. Filter is mostly used to protect orginal glass of lens from dirt smudges scratches & rough treatment. Keep on lens most of the time.
Hyda brand name. PL 3 i believe to be a dark polarizing filter.
Quantaray 1A4 I believe is a haze or skylight filter.
Haze filter does almost the same as a skylight filter.
Hanimex brand name. Polarizing filter used to shoot through reflective glass or surfaces (water), also in color used to sharpen colors. The reason it is turnable is it is light directional beaning light comes through it at a angal hold up to light & turn it you can see how it darkens or litens. Also can stay on lens when not useing skylight filter.
reason you have 2 is one of each for two diffrent lens, 49mm & 55mm.
Hope this helped. Please rate.Thank You.
Is the quantaray 55mm lens hood compatible with a d40
yes and no. no because the lens diameter of the 18-55 is 52mm and yes if you use a stepping ring that you screw on the 18-55 to accommodate the 55mm hood.
Quantaray 7500 flash
You will need a minolta pct-100, the will allow your flash to work with your Sony A-100
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
