The phone restarts on its own. It has happened a few times and everytime its been in a pocket and hasnt had any buttons pressed
Check the battery connection, if the battery is loose/moves around when you touch it with your finger, try putting a piece of paper on top, or the side, or which ever way it moves. So the battery will still touch the battery contacts. If this isn't the case, try doing a hard reset. Go to start>settings>system>clear storage. (It's like this in my htc diamond, not sure about the touch HD, but should be same) which will erase all data/contacts. Make sure you sync your contacts to your pc to save them!
If your htc mobile keep restarting this means your battery is very low or completely drained.Recharge the battery and then start the mobile.
During recharge dont start the mobile let the battery be chared for 1 hr then if you want can start mobile. It worked for me it just the sign of battery low .
Yup, have the same problem - damn phone turns off when its sitting on my desk and, even more annoying, might turn off and restart 3 or 4 times during a short conversation. Took it back to the shop and, guess what - the shop is vacant. Phone is just a few weeks old and cost $750.
Ian [email protected]
Same here. I've had the handset a week and its shut down on me around 3 times a day so far. Very annoying. I've contacted the retailer and they will send me out a new one.............. when they are back in stock! Grrrrrrrrrrr!
Phone switches itself on with a message saying Power will be turned off, and u may loose data if u have not saved them. Do u want to continue?
