It stopped recording. the screen said OPC ERROR and the cd ejected, why did this happen?
So far as it looks from other information in the works that this problem is caused by defective media. I always use Taiyo Yuden discs and have had few rejections in over 600 discs. Supermediastore is where disc supplies can be had as well as information on the error rates of different media being produced. The complaints recently were due to a bad batch released of hhb brand discs.
SOURCE: Still waiting for someone to contact me about
Hello
Its system control section does not get power at all. All other sections are working. This is due to a power supply section trouble inside. There is four regulators, fitted on-board, to regulate supply to different sections. Out of which, system control and display section doesn't gets proper voltage, Actually this is not a user repairable fault. A skilled work indeed. The technican must have a sound knoledge in digital electroncie to proceed with service. Just contact any service technician who is experienced in serviceing digital audio equipments. Never touch to system control section, without proper knoledge. Will make the device irrepairable. OK.
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
To remove a stuck CD from Tascam CC222
MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each
side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive
spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this
time.
6. Use a small screwdriver to prevent the
drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display
will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
