Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Toro 51591 and torro 51599 will not start
Toro 51599 and toro 51591 both worked fine, were left out of doors under complete cover (cold weather) and neither would start for next use, is there some repair possible
    New Friend:
The blower has a cover that snaps on to the tube and covers the propeller. I always use blow mode and it stopped working. I thought the motor was dead but flipped the cover to be in suck mode and it worked. I then put a layer of duck tape around the full circle of the blower side and it snapped in and works fine.
Posted on Jun 13, 2013
    New Friend:
These are ELECTRIC blowers.
Posted on Dec 15, 2009
  • 398 Answers
Try some starting fluid and change the gas
Posted on Feb 27, 2009
  • Anonymous Sep 09, 2010
    Electric means the problem is definitely not with the "gas."
    New Friend:
The ball bearing on the motor on mine froze up. I took it apart, and the ball bearing is toast, needs to be replaced.
Posted on Mar 20, 2010
6ya staff
SOURCE:
Nissan anti-theft door locks?
electronics do not like extremes of temperature .Wait till weather warms up before you start playing with it ,One tip is if its left outside in extreme cold do not lock vehicle ,
Jan 16, 2018 | Nissan Cars & Trucks
I have a Toro 8526 snowblower. Pull cord drags in cold weather- I have to use electric start-once started and warmed up, pull cord works fine-is this condensation you think?
Sounds like your recoil starter is dry. when it's cold it makes it a lot worse. I would shoot a little oil into the recoil. Even try a shot of WD40 and if that works use an oil can to shoot oil into all the moving parts
Dec 22, 2016 | Garden
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
I have a Toro self propelled lawn mower with a Briggs motor. It has the "Ready Start" feature that doies not want to work when cold. After several pulls of the starter rope and a few minutes...
There is a common problem with the ready start on early models. They tend to stick once moisture gets in them.
A dealer like www.arcolawn.com can do this under warranty for you.
Good luck
joe
Nov 11, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My toro lawn mower is hard to start in cold weather. (40 to 50 degrees), I have an auto-choke. mower was bought in spring of 2010.
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Nov 01, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
We had very cold conditions in our area (-35) for about a week. I could barely get the car started one day. the next day the car wouldn't start at all. All the interior lights and bussers worked and the...
could be a fuse. cold weather make the starter draw alot of amps. or if the starter selinod is the cold to to kick in the starter. I use a light bulb under the start sometime it helps.
Feb 11, 2010 | 1993 Nissan Altima
2006 sebring 4 cyl - in cold weather security alarm goes off whether i have it left unlocked - use key to unlock or fob - every morning it goes off - yesterday - when i was leaving work - went to unlock...
I know a quick fix to get it started but you might think i'm crazy to do this:
My 2003 Dodge ram van 1500 does the same thing. I put a small heater on the driver's side floor blowing the hot air toward the door.
I plug in the heater when I get home from workand let it run all night.
The computer for the alarm is under a kick plate near the driver's door next to the driver's seat on the left side. Once it warms up the alarm; it will shut off the alarm and you can start the motor.
Jan 06, 2010 | 2006 Chrysler Sebring
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
1,480 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
