CYLINDER HEAD GASKET PART NUMBER 11115 58140 USED.
SOURCE: what controls pressure in cooling system 1.5dci renault
I agree with Mike, but suspect you already have a measuring device to know the pressure is excessive. You should get the cap checked first.
But additional pressure that keeps coming out of the radiator above the release limit of 14-18 lbs is probably due to escaped compression from the engine cylinders. You will see bubbles inside the radiator while the engine runs.
Sometimes you will get water in the cylinder after the engine sets under pressure, but not always. Your engine works at about 140psi in the cylinder more or less. The radiator at 14-18 psi. A leak in a head gasket may take more than 14-18 psi to leak. So the leak acts like a one-way valve shoving air into the cooling system. Since the cooling system loses pressure as it cools, the water may not flow back into the cylinders when the engine is not running.
This is sometimes indicated in a cylinder bleeddown test where high pressure is shoved into the cylinder. Bubbles may be observed in the radiator from escaping air. Otherwise a compression drop in a cylinder may as easily be due to bad rings.
I hope my solution is helpful.
SOURCE: engine timing for toyota hino
dont start that car!!!!! you can ruin all your valves and create more of a headache.
