Olympus Sz-12 14mp Wide-angle With 24x Digital Camera Logo
Marnie Blankenship Posted on Mar 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I focus on a target, what is the reddish/orange camera icon in the left hand corner?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on Nov 07, 2013
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443429
Points
622693
The camera shake warning. The camera is warning you that under the current lighting conditions the photo may be susceptible to camera shake.
1helpful
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
1helpful
What setting do I use to shoot close up (macro) pictures of my items?
1) switch camera to "on"
2) Using the fwd, back etc control switch, located to the right of the screen, set it to "macro"
This is the left hand side of the ring switch. (back arrow). The macro icon (looks like a flower icon)will appear in the viewfinder in the top left hand corner.
3) to cancel macro, press this "back arrow" again.Or switch the camera to off.
I have just purchased Canon Powershot A480
I think the "busy" part can be put down to the camera performing a function or recharging the flash. The red icon I THINK shows that the camera is focussing.
With the last model it worked so that you could half press the button to focus on something (eg a fast moving pet) and then once your pet stopped moving your could fully press the button to take a photo and the focus distance would remain the same.
2helpful
I have an acer e300 and it is saying map not found how can i solve this
If you have loaded Destinator Console onto your PC from the original disc that contains the maps simply attach the SatNav to your PC and take the following steps
1. From "My Computer" identify the SatNav device from those listed in "Items with Removable Storage".
note. if your PC doesn't recognise the device try putting the memory card into a camera that you can connect to your PC.
2. Right hand click the relevant icon, and select "Format" from the drop down menu.
3. From Start Manu, All Programs - select Navigation (this will depend upon how you origianlly loaded Navigation) then select Destinator Console.
4. In the bottom right hand corner of the subsequent window there should be a box named "Target Device" - click "Change"
5. From the pop-up window select the device you have just connected. This device should now appear as the target device and it will show how much available space is on the disk.
6. Finally from the top left hand box named "Standard Maps" select - UK_Ireland-177.0 MB and click on Install/Remove Maps.
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 • Cameras
Focus,
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Sony Mavica MVC-FD81
That's the manual focus indicator.
Try moving the switch on the left side from "manu" to "auto"
1helpful
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
