SOURCE: Brother mfc 420cn, machine error
Your waste ink absorber box has reached its limit. You have to replace the box (which is cheap, get one from your local brother service centre).
After replacing it you have to reset the purge counter and flushing counter.
This is not easy to do and I don't recommend it for anyone who is not technically inclined. You have to remove the front control panel, open the covers on the top cover assembly under the scanner. Unplug all the cables. Disconnect the ground wire (if any), remove the prop, remove the scanner assy by opening 90 degrees and sliding rearward. Put scanner aside. Remove four screws holding top case on, pry out the bosses at the front and remove the top cover.
At the rear you will see the flushing box or waste ink box. Lift it up a little. You should see two tubes attached. Remove the tubes and pull the box out. Dispose of old box. Attach the tubes to the new box and install it where the old one was. Reassemble in reverse order. Don't forget to plug in all the cables under the control panel.
Plug the unit in while holding down the Menu button. Keep holding until all the lights are flashing. Welcome to maintenance mode.
Press 8 and then 0. Press the Black Start key several times until you see Purge or Purge Count on the display. Now press 2, 7, 8, 3 to clear the count. Press Stop. Press 8, 0 again and the Black Start key several times until you see Flush or Flushing count. Again press 2, 7, 8, 3 to reset the flush count. Press Stop. Press 9 and 9 to exit maintenance mode. Job done.
SOURCE: machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
thanks.
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
SOURCE: I have a Brother MFC-8440
the machine error 78 refers to either the fuser section or the laser board
