I do not have a record mode on my Coby mp300. Why?
SOURCE: Coby MP3 player is full but songs do not show up on my computer
Hello!!
try reinstalling the mp3 player drivers if u have .. or last option is to format it ... And also check out whether the player has a reset pin on the outer part .. if u find it .. try resetting it!!
Thank you!!
SOURCE: coby mp300 mp3 player
have you tried holding the button for at least 20 seconds. It is a slow player. Volume control is too low increase volume.
SOURCE: I deleted the coby software on my Coby MP300
Easiest solution that comes to mind is find someone with the same player. see if you load the drivers on your pc in a file if the you can load it as a new device and open it using drivers on your pc. Just a thought. then load the files back on the unit once you get access.
SOURCE: I bought Coby MP300 used and memory is almost full and I need to erase whatever is in there.
You need to download a driver for the MP300 available from coby.com. Follow the instructions to load the driver, connect the MP300 directly to the PC (you can use a USB extension cable). You can then clear the existing data and load your new data. I can send you a copy of the user manaual if you need it.
SOURCE: Need driver information to install Coby MP300-1G
Hi, kindly get it here :
www.cobyusa.com/?p=doc
www.cobyusa.com/?p=faq
www.freedownloadscenter.com/.../drivers-COBY-mp3/mp3.html
Regards, Jay
