(No, not advertising. Just a good photo of the motherboard, if you slightly scroll down)
Look at the chart below the photo of the mobo. (MOtherBOard) Expansion Capabilities:
A) Two PCI slots (Two PCI Conventional bus connectors. Long white slots)
B) One PCI Express x1 bus add-in card connector.
(PCI Express x1 slot. The longer PCI-Express x16 slot is on top. Then the two long white PCI slots. Then the shorter black PCI-Express x1 slot)
You can use a Sound Card in an available white PCI slot, or if the black PCI-Express x1 slot is open.
Yes, I know, I'm getting to it, lol!
The Onboard Audio -> Intel High Definition Audio, doesn't have an output mixer feature.
My onboard audio - Realtek, (And on an Intel mobo), does.
[ Intel 915G (Southlake) motherboard. Has a Realtek audio chip, ALC860. I use the Realtek Audio Manager. Has Sound Effects, and an equalizer. What happened from the Intel 915G to the Intel 945GCL INTEL? Sheesh! ]
Suggest this if you have an open, available PCI slot,
(Usually only 16-bit. Plugs into a USB port where the contacts are not gold plated, as on a PCI sound card, or PCI-Express x1 sound card. I'm old school, and probably need to evolve ; )
But it could be just a Driver or Software issue. I would update the Audio Driver... go to: http://www.emachines.com/support/drivers.html and locate your PC Model the Download the Audio Driver. It shows 2... use the first one. If that fails try the second one... the second one will write over the first...
If both fail... then if you want to do it youself... head to a PC store. If you are mechanically inclined and can read directions... I would try it youself. You will need a PCI Audio Card... Install it at the very bottom or last Slot in the System. Of course Power unplugged and again follow the instructions.
Este es el sitio web que usted necesita ... ir aquí y descargar los controladores de sonido para usted. buena suerte, y por favor, un voto bien gracias
