HP Photosmart C7280 Laser Printer Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp Photosmart C7280 All-in-One doesn't print
Printer says "out of paper"..(glossy as was requested) Actually paper is Matte, but there was no box to check for that. Put in regular paper then changed to matt. Printer makes noise that sounds like it is printing, but nothing comes out. Is it jammed? How to fix?
Thank you, asap if possible.
Ben Johnson
Level 3:
  • HP Master 686 Answers
  • Posted on Jun 09, 2009
Ben Johnson
HP Master
Level 3:
Answers
686
Questions
0
Helped
256870
Points
1918
Sorry, this isn't ASAP, but here's a solution on HP's website.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=3204785
The most important part of this is taking off the rear door / duplexer and cleaning the two rollers that you can just see inside the printer with the back off. Those two rollers inside the back of the printer (not the ones in the door or the ones hanging out the back when you take off the rear door) are the ones that pick up the paper and feed it up into the printer. Those rollers are hard to get to - long qtips are strongly suggested. If those get rollers dust or gunk on them, they get smooth and don't pick up paper as well.
Click the link for detailed instructions - don't just go with my summary of the solution.
1 Related Answer
Ben Johnson
  • 686 Answers
  • Posted on Jun 17, 2009
SOURCE: HP Photosmart C7280 All-in one says "out of paper".
If you get an 'out of paper' message when you do have paper loaded, this video will help. Following the steps of this video, you'll see if there's paper jammed in the printer.
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
How to print onto glossy photo paper in paper tray from my pc
set your printer with the paper size and selecect the type of paper - HP glossy paper. Youmight want to check below link for more details of any of HP printer issue
http://pc-and-peripheral.blogspot.com/
1helpful
HP Photosmart C7280 All in One Printer. I am trying to print on new check paper, but it just keeps running it through and then prints on the regular white paper. Any quick fixes?
Check the preferences setting in your Printer Dialogue box (the pop-up that comes up when you attempt to print... the paper settings may be set to standard, which you can modify...
A quick-fix is also to simply print to plain paper, place the newly-printed form in the scanner, and press "copy" on the printer itself (the physical button, not from Windows), with the check paper loaded (place in just one sheet, as not to waste ink)
Hope this helps!
-- RT
2answers
3helpful
3answers
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
k24674
Grand Canyon Tech
Grand Canyon Tech
