Sony KDF-E60A20 60 in. LCD HDTV Logo
Anonymous Posted on Mar 15, 2013
Replced bulb starts to power then fail red light blinks thre times
Before replacing bulb had red indicator light bulb was foggy replaced bulb and now red indicator light blinks three times conceutivly ?
  • Anonymous Mar 18, 2013
    Is it possible that there is a sensor on that bulb door ? It acts as if the bulb is no good cause the bulb doesnt even light up at start then goes to the 3 blinking red light under power. where would i replace the door sensor or can it even be done ? can i override the sensor ? Thanks
  • Col Dana Gillespie
    Col Dana Gillespie Apr 26, 2014
    Go on the internet to the company web site and see what "3 blinks" means. It's a code and it could mean anything from a door switch not completely closed to a bad ballast. Find out when the "3 blinks" mean then get back with me if you need to. Col. Dana Gillespie
Anonymous
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on May 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
18442
Points
73
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
5 Related Answers
Anonymous
  • 137 Answers
  • Posted on Dec 07, 2007
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Anonymous
  • 432 Answers
  • Posted on Jul 07, 2007
SOURCE: Blinking Red Power Light
It sounds like the horizontal (H stop) and vertical (V stop) has gone bad. Check Cap 515 and 516. IC1509, Q1505 and the jungle IC, IC206. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC.
Anonymous
  • 10594 Answers
  • Posted on Feb 21, 2009
SOURCE: replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Anonymous
  • 10 Answers
  • Posted on Sep 01, 2009
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Anonymous
  • 10594 Answers
  • Posted on Oct 19, 2009
SOURCE: KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
1helpful
Sony Wega kdf50we655 replaced bulb lights flashes green five times then goes red what's the issue?
the 5 blinks is indicating the lamp driver (ballast) has failed. You can get the replacement ballast for your model at the top of the following page
http://tvcircuitboards.com/sony_projection__dlp_circuit_boards
They can also assist with installation information,
2helpful
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
15helpful
2answers
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
3helpful
2answers
Blinking red light
replce lamp ballast board of your projector...
3helpful
2answers
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
1helpful
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
