Once the date has been stamped onto the photo, it's just as much a part of the photo as anything else in there. Whatever might have been there before under the numbers is gone. You can crop it out, or mask it, or remove it by editing the photo, the same way you might get rid of a garbage can or other unwanted object in the corner.
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
SOURCE: date stamp on photos for Canon SD100 IS
I believe you are referring to the PowerShot SX100 IS, as there is no SD100 IS. And yes, it does have the date stamp option while the image size is set to the postcard mode.
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
