Would like date displayed, not just edit the date, but displayed along with the time at the bottom right hand corner of my computer
This is for windows 7,
1 - Right click on the taskbar and select properties
2 - Under the 'Taskbar' tab you'll see the 'Notification area', click the Customize button
3 - Click on "Turn system icons on or off"
4 - The first item should be clock. Select on instead of off.
5 - Click ok.
SOURCE: help
hi bigbaz
maybe its hardware failure caus, open your case, and find the cmos jumper, clear the cmos with move the jumper to pin 2,3 and power on, after that power off, and back the jumper again .
close case
and power on again
i hope it can solved your problem
thx
cropp
SOURCE: how do i change the time(bottom right hand corner) on my emachine
right click your time in taskbar
click adjust time and date
SOURCE: Explain how to set the date in the bottom right
For immediate
results in fixing the date and time on your computer, double click on the
taskbar at the bottom of your Windows screen. This is located on the bottom
right-hand corner of your screen. The date and time control panel on your
computer will automatically open.
Adjust the
Properties
Double click the clock. A smaller date and time properties menu will open as
soon as you have double clicked on the time at the bottom of your Windows
computer screen. To set the date and time on your personal computer, the
process is quite simple. You can use your mouse to click on the correct day,
month, and year. You will also see an image of a clock on the right-hand side
of the properties menu that will display the corrected time that you have
entered. When you are pleased with the corrections, simply click on the OK
button on your computer screen. Most modern computers automatically adjust for daylight savings, but
several older models do not. As a result, you will need to update the time as
mentioned.
Time Zone
Adjust the time zone on your computer by clicking once on the time zone tab
that is displayed on the same properties menu that opened when you clicked on
the clock at the bottom of your computer screen. To set your time zone, you can
choose the correct time zone from the drop down menu. Use the small arrow to
show the options in the time zone menu on your computer. Once again, you can
click OK when you are finished. If you choose to have your computer
automatically updated for daylight savings, then be sure that the small box at
the bottom of the time zone menu is checked.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
