I cannot erase pictures that have been protected. how can i un protect them/
Unprotect them the same way you protected them. See pages 134-137 of the manual at http://gdlp01.c-wss.com/gds/5/0300004755/01/PSELPH100HS_IXUS115HS_CUG_EN_02.pdf
SOURCE: how to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
SOURCE: Can't un-protect Images in My Canon Rebel XS
It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
SOURCE: When I try to take a picture on my rebel eos 450D,
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting the card from writing. The position nearest the contacts unlocks the card. If the switch is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try another card.
SOURCE: "card protected"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
