There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
