Hi. please can you helpme find a hard disk for my Compaq Evo N100v laptop? it says non system disk or disk error.
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
The disk you describe is a standard size and should be available anywhere disks are sold. There is nothing special about it. Just make sure that you purchase an IDE drive not SATA.
Dan
Dan
sir, do you know where i can buy thes for my Compaq evo N1000v
> 512MB, 266MHz, PC2100, DDR-SDRAM DIMM memory
module - 2.5V core voltage
> Battery (Primary) - 8-cell lithium-ion (Li-Ion), 14.8VDC, 3.9Ah, 56Wh
> 60.0GB IDE hard disk drive - 5,400 RPM, 2.5-inch form
factor, 9.5mm height
is other ide hard disk compatible to my laptop?
thank you
[email protected]
09154225315
(02) 572-8570
