Water is leaking in the bottom under the crisper.
SOURCE: water builds up under crisper bin then leaks on
unstop defrost drain under evap in rear bottom of freezer
SOURCE: GE with top freezer has water accumulating in
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you.
I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
SOURCE: water leaking on floor. wateron top of crisper
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Make a clip at the other end of the wire , and " clip " it over the glass tube (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
SOURCE: my Hotpoint refrigerator is leaking puddles of
It is most likely due to a clogged defrost drain. I put together some instructions on cleaning the drain, follow the link below and let me know if it was helpful.
Drain Leak
