I'm trying to connect a DVD player/recorder to a VGA monitor. I purchased a converter said to do just this. All connections have been made as directed and rechecked. I get a prompt saying video connection out of range. What am I doing wrong?
SOURCE: JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
SOURCE: Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
SOURCE: can't connect camera to computer
means either istallation is not done properly or there might be a problem in usb cable.take out the usb cable and connect it again tightly then it eill show you on the desk top that Everio is connected.
SOURCE: Connecting DVD player to Viewsonic TV
You will use component video cables. They come in threes and all they require you to do is connect the DVD output with the TV input and match the cable colors on both ends. They will be red, white, and yellow. The yellow is the video, and red and white are left and right audio. If your TV is too old to have stereo audio, only one (red or white) audio cable needs to be connected. It doesn't matter which. The yellow cable always needs to be connected.
Another option, but a slightly less common one, is to use a single AV cable to connect the two. The reason this is less common is because most newer TV's do not have AV input, and newer DVD players do not have AV output. If it does, however, this is the most simple, and you probably wish to take advantage of it, so you have a connection available when you purchase a newer unit which does not have AV.
