I will be watching a program and the receiver will go into to the standby mode(no sound) without notice. i will switch it back, and two minutes later it will go to standby mode.
This receiver is likely to be overheating or has a shorted speaker wire. If the unit is very warm when it shuts down then it is in need of some additional ventilation. Onkyo's tend to run hot so this is critical for proper operation. A speaker wire problem could also cause an issue when the unit detecs a no load situation.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Left the cabinet doors open when on. Has not been a problem since!! Thanks!!
