car blue led light is continuously on and it won't chirp. I have a Honda Passport 2002 with Python 700 installed on it by Circuit City. I do not know where to go to have it checked.car blue led light is continuously on and it won't chirp. I have a Honda Passport 2002 with Python 700 installed on it by Circuit City. I do not know where to go to have it checked.
You can't post conmments that contain an email address.
Try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
no car told
and added remote engine start kit
ask maker of car if this is allowed at all
on many cars it IS not;.
no car told at all not one clue
first ask maker what to do ,car maker
some have kit that allows this. others do no.
modern cars the IMMO system thinks it is being hacked
(and is) and does bad things, even random or worse.
auto bricking PCm.
hello
u'd need a proper manual for this in my opinion
like there are plenty of dealers and online shops that deal in those..
you can get some free at sites reliable-store.
and it;s actually really illustrative
AnandTech
Feb 3, 2003 - 11 posts - 7 authors
My car alarm doesn't chirp all the time, but it still unlocks the doors. ... Distributed Computing. ·, Security. ·, Social. ·, Off Topic ... The rest of the electrical systemseems fine. ... Just read the owners manual and find out to to re-enable the ... but like when I arm my alarm it arms but then it'll go off for no reason.
When you try to start the car the alarm goes off.. It could be your battery. 3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery ...
www.tintdude.com > ... > 12 Volt Forum : Car security / Convenience
Sep 11, 2006 - 7 posts
posted in 12 Volt Forum : Car security / Convenience: Hi I am new to this site ... Myproblem is when I lock it it won't chirp or roll my windows up ... If I hold the lock button the siren will go off,and if I press and hold the AUX my windows will go down. ... It won't chirp when activated or when I hold the arm button.Missing: hornet
? 3:34
https://www.youtube.com/watch?v=r01ntAXGxBw
Mar 10, 2011 - Uploaded by Lessco Electronics
hi I have the viper 7142v alarm system,tge problem is I only had one remote,I ordered a spare but ... My alarm only chirps when i am programming lock and unlock functions. it does not ... As soon as I connect car battery my alarm goes off. ... I obviously don't have a remote, and it doesn't have a valet switch.
That second chirp is a status alert letting you know a zone was not able arm yet. Most common reason is that the dome light its not out yet. It arms itself as soon as the trigger goes to sleep.
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
what is happening is your dome light stays on for 30 seconds after locking your doors and the alarm is sensing that a door is still opened and is giving you a warning chirp that a zone is still opened. Some alarms will have a bypass in the menu setup that will bypass the open zone for 2 min after arming. check your owners or installation manual if it is indeed the case.
