Problem with washing machine
SOURCE: we have a Neff washing
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced but first check to assure that nothing is stuck inside the pump or one of the lines goiing to the pump they are not expensive if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
SOURCE: Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
SOURCE: Wont Drain
If there is a drain issue, sometimes there is an obvious solution. Check the
drain hose for any kinks, as well as checking any lint filters in or on the
drain hose. Is there a lint sock on the end that's full? Perhaps the drain line
itself is plugged. You will want to make sure that the house drain system is not
backed up or plugged. Always make sure that the washer drain hose is above the
level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a
side-check valve near the tub outlet which may get clogged. A standpipe should
be at least 1 1/4 inches in diameter, and never seal a drain hose into a
standpipe. This can lead to back-siphoning. You also want to make sure that the
standpipe is less than 96 inches in height.
Pump problems show various symptoms. Sometimes the pump will lock up and
seize. If the motor is running, it will continue to try to turn the pump. In the
case of belt-driven pumps, the belt may break or burn through. The pulley may
shear off. If there is enough tension on the belt, and the motor continues to
try to turn it, you may wind up with a seized motor as well. The pump itself may
have seized bearings, be jammed by clothing or another object; or the impeller
blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the
hoses. Look inside the hoses and see if there are any obstructions. Feel around
inside the pump inlets for anything that may be jamming the pump itself. You can
also use long-nosed pliers to feel around inside the pump for any items that may
be causing a jam. If you haven't found a jam, and you still believe there may be
a jam in the pump, you can completely remove the pump from the washer and
inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part
may go bad. Some older washer models have an electric-mechanical shifter. If it
won't shift, it's best to call a professional appliance repair person to address
this issue. If your transmission is leaking oil, there are really only two
options at this point, either run it until it dies completely, or replace it
now.
SOURCE: neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
