Question about A.O. Smith SQ1102 Pool Pump Motor
AO Smith model #c48a95a06 has power will not start
Pump says its wired for 230 volts although internally it seems to be wired for 115 volts. It has incoming voltage that meter says is about 102 volts. It will not start or even attempt to turn over. Is it voltage loss or a bad capacitor/
2 Suggested Answers
6ya staff
SOURCE:
JUANITO
SOURCE: AO Smith SQ1102 pump motor:
On your motor name plate there is a diagram with motor terminal numbers that shows you the feeder wires connections for 115 & 230VAC. You don't need to change any internal motor wiring connections because those are only CW or CCW motor rotation. As you told it tripped your circuit breaker, b4 u will attemp to make any connection you need to test your motor's winding insulation insulation first by using megger tester or ordinary analog tester clipping one lead to the casing and one lead to the motor terminals one by one.
Posted on Aug 01, 2012
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Just replaced a Hayward 2hp pool motor with a OA Smith 2hp pool motor and when i turned it on it starts to switch between high and low and it shuts off. the motor makes a tic tic sound. What do you think...
Hello
No there is no switch in the motor.Correct voltage is done by hooking up incoming power to a combination of internal wires or contacts.
There should be a wiring diagram on the cover where the hookup is.Or on the outside case of the motor.
The high and low speed doesnt make sence to me.Check the rpm of the motor it should be one rpm continueous.
Unless this is a Hvac motor and not a pool pump motor.Possible you may have been sold the wrong motor.
Usually a pool pump is 115 volts 1 speed and 1 rpm continuos duty.Unless you specify 230 volts.
Aug 09, 2011 | AO Smith 2 HP 115/230V 56C Replacement...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
We have a Gould's J10S 115/230 well pump with a A.O. Smith C48A95A06 motor. When the pump sits for 24 hours and then we use it the pump shuts down. If we restart it the pump then runs fine. We have...
your replacing everything but the problem part which boils down to the pump its 10 yrs old and you havent tested it either bearings or winding failing in motor
Apr 25, 2017 | Plumbing
A.O. Smith SQ1102 Pool Pump Motor Logo
210 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
