Purchased new sim card and cannot switch apps from phone memory to sim card . under manage apps screen does not light up under move to s d card
Do you mean from internal memory to SD card?Some apps can not be moved to SD cards.Also if you replaced your sim card the apps are on the old card.You would have to backup your apps from the old sim card to the external SD card then re-install them.Some cell providers have online back up that you can use.Good luck.
SOURCE: htc phone saying memory full.
Make sure your sd card is not corrupt. It should auto save to your sd card. You will probably want a card that is at least 2gb. Go into settings, sd card and phone storage, and make sure unmount sd card is brightest. This means that your card is in and recognized. At the bottom of that screen, you should see internal phone storage, here it will tell you how much memory is free outside of the sd card. You will want this to have at least 100mb free so that the phone can operate at is smoothest.
SOURCE: sim card rejected / insert sim card
SIM card rejected means the SIM card has failed, it needs to be replaced.
Best of Luck.
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
SOURCE: N70 move messages to memory card?
1. its an easy method to Move messages from phone to memory card
2. Select >Messaging> from the main menu. Select >options in the messaging. Select >Settings.
3. in that Settings options. Locate >Others
4.Select >others. Select >Memory in use. in that change from Phone memory to memory card.
5. Enjoy !.. thank you
