This micro has a glass panel, and that is not the problem. The problem is the UIB part number WPW10391271, it can be replaced by removing the door panel (screws plus snap click). it is Be careful with the 5 colored wires connecting it to the body. You can disconnect them by opening the left panel from undeneath
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Hello there Jerry Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok Best regards Mike
Just had my Kitchen Aid Microwave KHMS155LSS burn up and bellow smoke.
Thankfully, I was close by, stopped the microwave, vented the smoke, turned off the circuit breaker and unplugged it. Still the smell of burned motor, burned plastic has me concerned. Did it get hot enough to cause problems behind the drywall? So far, I am keeping a "fire watch" to make sure nothing is smoldering.
