Hi i am nitesh patel from India and the problem is that my video ipod has been lock after i had given wrong password and the message on the ipod is giving that ipod is disabled and connect to itunes and i had done many time but it don't work so pls. help me out of that.
You might be able to restore the iPod,
you just need to put it in a different mode. Try plugging it into your
computer. Press and hold both the sleep and home buttons at the same
time until the screen goes black (can take longer than 10 seconds) then
let go of the sleep button (the button on the top of the unit) while
keeping the home button held in (the button on the front of the iPod).
Keep the home button held in until your computer recognizes new
hardware. You should hear some sort of sound coming from your computer
speakers. That and the "installing new hardware" notice should come up
in your taskbar (this is where you computer shows the clock). Let go of
the home button once this happens. Open up iTunes and then restore it.
Just a little FYI - it may take longer than 4 minutes before you can a
response. You might want to wait at least a few hours before bumping
your thread. Remember that this is a normal work week and not everyone
is on these forums during normal working hours (ie 9:00 AM to 5:00 PM).
Most of the traffic here on iLounge is during the evening.
If you have forgotten the code, you can unlock the iPod by doing the following: Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
My ipod is disable.and it shows'ipod is disable connect to itunes.in red box.what can i do now .please help me.
Ipod is disabled connect to itunes
K i did the 1st solution n now my ipod is off. i tried everythinq but it won't come on. help me plzzzzzzzzzzzzzzzzzzzzzz?
I keep trying erry thing but my ipod wont come in disabled
well my name is kelmarys. my i-pod touch says is disable.i conect to i-tunes but it still doesnt work.i need help
me to
it says disable connect to itunes and i did that three times and it still dont work
