I was trying to reheat food, I entered 1:30 min, 60% power... instead of touching start, touched power accidentally again, then pushed start and the oven shut itself off. I tried to unplug & plugged it back in, but still it's still not working. is there a reset process or button?
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: fan in the GE microwave (over range top)
Can you reply back with your full model number?
I'm suspecting you may have a failing keypad (membrane switch) on the control panel assembly.
We repair these for customers nationwide by mail for $39.95 plus part cost.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you want to do it yourself, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
SOURCE: MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
Whichever option you choose, we have
the service manual for this model and have uploaded it to our
site here to help you.
You will need the free
Acrobat Reader
to view or print it in case you don't have it already.
We're
