Question about Samsung LA26R71BD 26 in. HD-Ready LCD TV
"Weak or No Signal" message on Samsung 26" LCD TV
Why is it that more often than not, I get the "Weak or No Signal"message on some of my channels? I am hooked up to cable (no box -- just have it for the reception). I tried the cable setting, as well as the TV setting. Didn't have this problem with my old analog 13" television It is VERY frustrating! The TV has a mind of its own!
  • Scott Frye
    Scott Frye May 11, 2010
    Hi....
    Are you using the chrome screw-on type connect for the cable?
    Does the one on the TV seems loose and, have you tried a new cable between the cable box and TV yet?
    Let me know
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Posted on Nov 07, 2009
Why do I loose the signal on channel 26 only?
sounds like a weak signal might help if your antenna was on a mast for a better reception
May 05, 2014 | Vizio L32 32 in. LCD HDTV
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
I get a 'weak or no signal' message and can't get an AV2 choice at all , just 'free to air' tv channels
reception issues require a better signal source, attic or roof antenna should solve your dilema
Samsung should stop at AV2 when something is plugged in the correct socket, if it doesn't check for a bad cable.
E
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 01, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Is this a joke? How am i suppose to get help?
Dec 17, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LA26R71BD 26 in. HD-Ready LCD TV Logo
3,270 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
