I set the self-cleaning option. I had to cancel it. When I pushed the cancel button, the F9 error code came up. Then it started beeping. Door lock light began flashing. There was a noise like the door lock mechanism was trying to engage or disengage. Continued beeping. Beeping finally stopped. Door lick light still flashing. Unable to use oven
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Eso es exactamente lo que pasa, c?mo lo soluciono?
