I have a GE WBVH6240HWW Front load washer. I tried to start a regular load. The washer started up, water went in and it started to wash for about 4 minutes, then it just sat, wouldn't switch cycles, drain, just sits, but the time left on the load keeps on going. When the time is done, it signals the load is finished and shuts off. Water is still in the drum, but door unlocks as if it washed the load and went through all the cycles. Any ideas?
I would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
As others have said - remove the door on the lower front. There is a plastic guard on hinges that you can flip to the downward position giving access to the filter screen and acting as a water deflector for when you open the clogged screen and it drains onto the floor....Clean he screen, replace everything, and power it on. After self-checks it will unlock the door.
