Moved into new house, it has a new Ignis single electric fan assisted oven which lights up and fan works but oven doesnt get hot. Any Ideas?
Thanx In Advance
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown. Hope this helps.
If it is a fan assisted oven and the fan is working o/k, then it is likely to be a faulty oven element, this is usually located at the rear of the oven compartment behind a removeanble cover.
Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
If you turn the grill on, then only the top element will get hot in the oven.
if you select oven and it is fan assisted, then you will hear the fan working, and feel it blowing hot air.
Hope this helps.
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
