Kenwood KDC-MP628 CD Player Logo
isaac Posted on Mar 12, 2013
Reset security code for kenwood 628
System is asking for security code after jump starting my engine
2answers
Can I reset the security code on a kenwood kdc-x859 without the remote
You cannot reset the security code. Once it has been set, it is part of the system's operation. You should be able to bring it into a service depot and they can reset it, but you will need your original receipt.
If instead you are just asking how to enter the code without a remote, you can just use the controls on the deck just like you would with the remote. Check page 30 of your manual or download it here:
http://manual.kenwood.com/files/B64-2215-00.pdf
I need your help to know the code its No 11201951
Here is some good info from another site (as linked below):http://www.tech-faq.com/how-to-reset-a-kenwood-security-code.html
If these methods don't work you would have to send the stereo back to Kenwood to be reset.
Common Kenwood Security Codes Many Kenwood radios are configured with the same security codes:
  • KCAR - This seems to be a "backdoor" to some Kenwood models.
  • 3051 - This is the security code which is printed in the manual of many Kenwood models.
  • 1234 - This is a security code commonly chosen by Kenwood owners.
kenwood-security-code.jpg Entering your Kenwood Security Code If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
  • During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
  • Enter the security code using your Kenwood remote.
Type 2
  • Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
  • Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter - then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
  • 5
  • 5
  • Track Up
  • 2
  • 2
  • 2
  • Track Up
  • 2
  • Track Up
  • 7
  • 7
  • Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in Some Kenwoods There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
My system is blocked on secuirity code enter when i switch it on and i don't have the code. My car stereo is a Kenwood KDC-MP638U. happened when i removed it from one car to another car. have tried using...
Finding the Kenwood Security Code
There are backdoor codes for each Kenwood car stereo, based upon the model and the serial numbers.
These backdoor codes are closely held secrets. Outfits like Car Audio Accessories UK will sell you the code for your radio for £20.
Sending your RadioBack to Kenwood
If all else fails, you can send your stereo back to Kenwood to have the security code reset.
I dont no how many watt my amp has
Hi and welcome to FixYa,
To my understanding, a Kenwood KAC-628 is rated with max power of 100 watts X 2 at 4 ohms per channel. Incidentally, it is bridgeable resulting to 300watts X 1.
Good luck and thank you for asking FixYa.
1helpful
Bought kenwood cd player 7011
Entering Your Kenwood Security Code
Type 1
Type 2
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
5
5
Track Up
Track Up
Track Up
7
7
Track Up
A Security Code Bug in some Kenwoods
1helpful
Need code for Kenwood kdc-mpv7019
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Cannot remember my security code after reset Kenwood kdc-mp435u
Try code KCAR entered from the remote. 3 entry methods are detailed below.
Type 1
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
5
5
Track Up
Track Up
Track Up
7
7
Track Up
i hope this works for you.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
