Oil leak on back driver side motor in a 1994 dodge caravan
Place a piece of white paper/cardboard on the ground below where the leak is coming from soon after the engine is turned off. This should help you locate where exactly the oil is dripping from, and should help identify what is leaking. If the oil is black/brown/gold, it's probably engine oil. If it's reddish/brown, it's probably transmission fluid. If it's clear, it may be brake fluid or power steering fluid (from the rack/pinion). Check the fluid levels for whatever you determine it may be. If it's engine oil, you may have leaking valve cover gaskets or a leaking rear seal on the engine. If it's transmission fluid, you may have bad transmission cooler lines or leaking from axle seals. Check the master cylinder and brake lines if it's brake fluid, and check the rack/pinion if it's power steering fluid.
