All the data on my SD Card disappeared, now showing only one file USBC. This virus entered my SD card via friends USB. I badly need my data. Anyone please help!!! I haven't deleted any of my files. And now i am unable to locate them on the specific folder. There were only video files (.MOD) on my SD Card. Someone please help me get back my videos.
This program may help.
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
I didn't work. Recuva is unable to detect my lost .MOD files
Insert the memory card into an USB memory card reader and connect the card reader into a computer with a virus scanning program then scan the memory card and remove the virus.
i have inserted the SD card into my laptop. But my antivirus is unable to tackle this kind of virus.
Try a WEB base virus scan. WEB-based Virus Scan Trend Micro HouseCallhttp://housecall.trendmicro.com Symantec - Norton Security Scanhttp://security.symantec.com
Regardless of what virus your SD card infected with, they should be killed first. Generally, you will get back your lost files when finish killing the virus. But if you unfortunately lost the card files, then you need a powerful and easy to use card file recovery tool. For more information, read here: http://www.card-data-recovery.net/ Best wishes!
1. Open run (windows+R)
2. Open command prompt (type : cmd)
3. On the open box type -> chkdsk (space) [the drive]: (space) /f
example (your sdcard is on drive K -> chkdsk k: /f
4. It will say that it's being repaired , after that
5. Copy all files inside DCIM folder to your PC
you will find many files with FILE00XXX.CHK format. If your images are all JPEG, you can just change the .CHK file type into .JPG
But if you have the RAW file, it will be hard, because you don't know which one is the JPG/RAW file.
So you need to download this : http://www.ericphelps.com/uncheck/unchk3.zip
and this
http://download.microsoft.com/download/vb50pro/utility/1/win98/EN-US/Msvbvm50.exe
It will automatically change the files into JPGs and you change another .CHK files that haven't changed by the program into your RAW file format (Olympus = .ORF , etc)
Example :
There are 4 .CHK files :
FILE0001.CHK
FILE0002.CHK
FILE0003.CHK
FILE0004.CHK
if the result =
FILE0001.CHK
FILE0002.CHK
FILE0003.CHK
FILE0004.CHK
then the file002 and file004 is RAW:smile:
Hope this helps and don't be afraid when you have this problem! :smile:
I've had this same issue a few months back and I was able to recover some of my files with this software SD Card Recovery Software Pro FREE Download.The thing is...once you've discovered that your sd card files got corrupted you should stop using that card. You don't want to overwrite the files and lose them forever.Connect the sd card to your pc and run the software.
In a few moments you'll know if your files are retrievable. All the best
Use a card recovery software to retrieve your videos back. Simply insert the Sd card to your computer. Download and run a recovery software on your system. Follow the recovery instructions and you will be able to retrieve your video files back. But before starting the software, remember two points.
1. During recovery, always keep the affected source drive and the recovered files destination drive separate.
2. Do not use further the Sd card after data deletion until the recovery process is complete.
I have used Stellar Phoenix Photo Recovery Software which is a pretty good software for recovering videos or photos from all kinds of storage media.
Damaged SD card is the common SD card problem of the digital camera users. Generally SD card becomes corrupt due to accidental shut down. Your photos may become inaccessible when it happens. you might have to face critical photo loss condition. In order to recover damaged Sd card photos you would have to use Photo Recovery third party tool. Some days back I got same condition while transferring photos. In that case i Download this free photo recovery software and recovers lost photos. Easy user guide helped me a lot to recover deleted files from SD card
SOURCE: I have a 16 G
Hi.
ASMI SD is not a type of file. It is the name of the card reader. Asmi is either the name of the card adapter (the slot) inside the camera, or the name of a card size adapter. Here a brochure showing ASMI adapters.
The card has lost formatting and the camera is either displaying the card reader name because the camera is unreadable, or the card is showing ASMI SD as a file name because its formatting is defective.
When that happens the files are often damaged or lost. The only attempt you can do to recover files is by connecting the card to a computer and then using a data recovery software.
Check also If the card is using an adapter. In that case you will have a smaller card inside an adapter that looks like a bigger card, as shown below. That adapter is ASMI as the slot inside the camera. If using an adapter extract the smaller card from inside and test using a computer.
With or without adapter pull out the card and read it using a computer. If the computer has no built in card reader, get an USB reader like this:Card reader .
First try reading the SD card without recovery software. If that does not work and files are still not displayed, install a recovery software and try recovering the files on the damaged card with the recovery software. Below a choice of files recovery software. Some of the software is free.
iCare Data Recovery Freeware
Undelete Software data recovery
Free SD Card Recovery
Data Recovery software
File Recovery Download
Freeware downloads System Tools
SOURCE: Jazz HDV178 videos from SD card not acknowledged.
SDHC cards need a special reader. A standard SD reader won't read a SDHC
SOURCE: I cant download video files from my Canon IXUS 850 IS
Use a separate card reader to transfer the video to a folder you create on your desktop. Try using Quicktime to open it.
SOURCE: Cannot view folders when connect camera with
Use a Memory Card Reader to copy files to computer.
Go to start ->click run->type in regedit and press Enter key.Now open HKEY_LOCAL_MACHINE\ Software\ Microsoft\ Windows\ CurrentVersion\ Explorer\ Advanced\ Folder\ Hidden\ SHOWALL.
In the right pane ..right click CheckedValue and select delete.
Create a new DWORD key (right click in the right pane in empty space> DWORD Value> then write the name: CheckedValue). All you need do is to change the value of this key (CheckedValue) in 1 (0 × 00000001). For this key, right click on Modify and change Value data: 1.
Download and run this script foldersettings.reg or showhiddenfiles.vbs
Download and install smart virus remover ...http://www.technize.com/filedownloads/smart_vr.exe ,scan your computer.
SOURCE: Cannot open files on SD, and there are corrupt files
Did you connect this SD card to your friend's computer before you connected it to your computer. If so your friends computer may have corrupted the SD memory card.
Try this recovery program.
Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
Go to these WEB sites to down Recuvahttp://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
