Ran dishwasher, in morning it was clear had not run and displayed the code h23. Turned off and on again still shows code h23
SOURCE: Dishwasher ran all night still
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
SOURCE: I have a Bosch SHU5316UC
P stands for program in computer algorthms. The device displays program whenver chages were made to the default settings. A powered on devices least has malfunction only requires reseting to attaon default features. Depending on the type of device, reset would be a button that is pressed held for an extensive duration to clear the entire corrupted data to make way for default. Refer to the device user guide also for further asssistance.
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Just found this and after a bit of playing realised it was a timer delay. Start in 23 hours. Little fingers or maybe got knocked. Hope that helps
