It has always been really easy to unscrew to empty but now it will not open. It is like something is jamming it but there is nothing to jam it. I don't want to force it and break it. Is there a way around it?
SOURCE: how do i open my
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
SOURCE: how do i open my dirt devil kone to empty it?
Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
SOURCE: Can you wash the filter in the dirt devil
no they need replacing > http://dirtdevil.com/file/661/
